Recessed light trim not flush
kevreh | Posted in General Discussion on June 24, 2005 03:13am
Howdy-
Bought some trims for my 4″ ic incadescent housings. Even though the retainer clips seem beefy enough, I can’t get the trims to sit completly flush against the ceiling. Any tips? The housing isn’t protruding below the ceiling so thats not the issue.
FWIW, the housings are Halo and the trims are Elite.
Thanks, kevin
  1. VaTom | Jun 24, 2005 03:18pm | #1
    Bigger hammer?
    1. DanH | Jun 24, 2005 04:32pm | #5
      Nah, it won't flush because the septic's backed up.
  2. TMinor | Jun 24, 2005 03:52pm | #2
    The Solution to all problems:
    CAULK!
    It's recognized as trim in my neck of the woods.
    Seriously though, you should purchase the same brands for the trim and can.
    -Chief of all sinners
  3. calvin | Jun 24, 2005 04:09pm | #3
    Not familiar with your trims but here are some things that have bothered installations.
    The trims could be hitting something inside the can/temp sensor, those bent out brackets for other style trims, even the top of the can.  If the can housing is adjustible, loosen the 3 screws on the side and slide it up a bit, the trim won't go up into the housing as far.  The bent out brackets, bend them back towards the side of the can.
    Quittin' Time
    1. kevreh | Jun 24, 2005 08:34pm | #6
      Thanks, good tips.
      I wasn't able to find anything that said the trims would only work with brands xyz.... so I thought I'd give it a try. I guess its no surprise, with different trims and different housing makers. The Halo trims are way spendy- $30+. The eLite trims I used (as well as others at http://www.usalight.com) are a lot more reasonable- @$10. But yeah, they don't fit 100%.
      I'm thinking of making a filler ring from 1/8" mdf or something.
      Kevin
      btw- I know its not the septic 'cause we have 'city' sewer :oP
        maddog3 | Jun 24, 2005 08:48pm | #7
        If you are going to make a "FILLER", just be aware of the heat those cans will produce. I would not put something that will burn between the trims and the cans maddog
    maddog3 | Jun 24, 2005 04:32pm | #4
    those trims are not designed for those cans , you can alter some things like calvin says, most likely though, the trims will never fit snugly, and you will be adjusting them frequently
    maddog .........numero 3
    1. calvin | Jun 24, 2005 09:35pm | #8
      glad you verified the numero maddog-o.  You dogs have become a litter.  But welcome (belated) to BT and good to see we have another electrician represented, the other guys have been overworked.
      Don't forget the fest, you're close.  Lemme know.Remodeling Contractor just outside the Glass City.
      Quittin' Time
        maddog3 | Jun 25, 2005 02:45pm | #9
        If work does not pick up soon , I will pawn my pet geese to be there. ok? maddog #3 overworked electrician? who would believe that?
        Edited 6/25/2005 7:47 am ET by maddog
        1. calvin | Jun 25, 2005 03:08pm | #10
          keep the goose, hitchhike.Remodeling Contractor just outside the Glass City.
          Quittin' Time
Outdoor Lighting
