Recommendation for Ridge Vents
jono1 | Posted in General Discussion on March 22, 2012 11:44am
Looked at a house for water intrusion and have decided that it has to be wind driven rain penetrating the baffels on the ridge vents. They are the aluminum type that viewed from the end look like a mushroom with angled louvers under the cap. They are fully caulked.
Any recommendations on a better design ridge cap?
Thanks, Jon
  1. DanH | Mar 22, 2012 08:22pm | #1
    We've had the standard molded plastic ones for about 25 years and have had no leakage that I've noticed.  The first set was the "ShingleVent II", but I'm not sure what was put on the last time -- something similar.
    (Note that caulking may be a bad idea, depending on the design.)
  2. IdahoDon | Mar 23, 2012 11:04pm | #2
    Many times ridge vents are simply on the wrong side of the roof if the wind is normally from one side.  Even a continuous ridge vent under the ridge cap doesn't have to be open on the upwind side.
  3. byrd48 | Mar 25, 2012 12:26am | #3
    Are any gable vents present?  If so, it could create a suction that would pull air (and water) in from the ridge vent.
