Recurring ceiling crack.
paintrboy | Posted in Construction Techniques on May 8, 2010 09:16am
I have a crack in one of my client’s bathroom ceiling’s and I am looking for other repair suggestions. This crack comes back every winter since 1998. I’ve tried DuraBond, Fiberglass tape, paper tape, plaster, Pro Flex caulk then skim, nothing is working. The joint is the source of the crack and has movement. I can’t screw or mechanically attach it because they have Radiant ceiling heat pads. Is there anything else I can try? This repair is getting tiresome.
  1. DanH | May 08, 2010 09:53am | #1
    You could try "wall liner", a
    You could try "wall liner", a sort of wallpaper designed to be installed and then painted over.
  2. davidmeiland | May 08, 2010 11:00pm | #2
    It doesn't sound like
    appropriate backing for drywall, and I wouldn't think you're at fault. Drywall needs to be screwed (and hopefully glued) to stable framing. Anything less is likely to be problematic. I guess if you really want to hit it hard you could try laminating another layer to the existing, maybe some 3/8". Run the joints the opposite direction.
  3. Scott | May 08, 2010 11:04pm | #3
    Seasonal truss flexing due to changes in temp and moisture?
    If so, I don't see how you are responsible.
  4. DanH | May 09, 2010 09:05am | #4
    Note that the radiant heating setup is likely making the situation worse -- may be the main cause.  It warms the framing, creating a situation resembling "truss uplift", only localized to the bathroom area.
  5. DanH | May 09, 2010 09:06am | #5
    BTW, by "joint" do you mean a
    BTW, by "joint" do you mean a running joint between sheets, or a corner joint?
  6. Scott | May 09, 2010 12:22pm | #6
    BTW.... you definitely get the "cryptic, arcane name of the century" award! LOL.
    1. calvin | May 09, 2010 01:54pm | #7
      Alright!
      Nice Rez-a-vation there.
  7. TLE | May 09, 2010 04:53pm | #8
    If it's truss uplift:
    If you can get into the attic, lay blocking across the top plate onto the drywall.
    Use glue against the drywall and nail or screw down to the top plate.
    Another possibility  would be using Sashco brand Big Stretch caulk in the crack - preferably when it is opened up in the winter.
    I would prefer the blocking method but I have seen that Big Stretch perform some miracles.
    Terry
