Redoing crawl space skirting – what t…
| Posted in General Discussion on September 2, 2000 05:51am
I am going to use pressure trated for the framing part, but what about the skirting itself?
I was thinking about wonderboard, but i don’t know how it would hold up outside….i was looking a tthe tile backing board products, but they all say indoor use only.
Any suggestions??
thanks
ted
ps: interior of framing will have 1-1/2″ foundation insulation to help keep the cold out.
  1. Guest_ | Sep 02, 2000 04:38pm | #1
    I'm not really "on line" with this whole concept, but how about PT plywood or one of the sheet fiber-cement products. For the latter, try the Hardie web site
    I don't know what your piers are made of, what your soil conditions are like, or how deep your frost line is, but a permanent solution would be to dig strip footers, and fill in between the piers with masonry - brick and/or block. They sell split face block that come in colors and look a little better than regular gray.
    1. Guest_ | Sep 02, 2000 05:05pm | #2
      *What height is the finished grade. Is part of your skirting below grade. What do you want for a finished looked. As Matt G said PT plywood would work, looks like crap though. Are you going to insulate the walls. What height is the skirting. I worked on an aquatic center awhile back and we used a rigid insulation that had about a 1/4" thick concrete face on it. The rigid insulation was 2'x 8'x 2" interlocking panels. It will never rot and you get an R value with it. Can't help you on where to get it in your area though.
      1. Guest_ | Sep 02, 2000 05:51pm | #4
        *Ted, cement board will work fine and can be stucco'd any time afterwards for a concrete look. Its easy to install and will last forever.Gabe
  2. ted_h | Sep 02, 2000 05:51pm | #3
    I was thinking about wonderboard, but i don't know how it would hold up outside....i was looking a tthe tile backing board products, but they all say indoor use only.
    Any suggestions??
    thanks
    ted
    ps: interior of framing will have 1-1/2" foundation insulation to help keep the cold out.
How Trump's “Big Beautiful Bill” Will Affect the Inflation Reduction Act
The Big Beautiful Bill could do away with much of the Inflation Reduction Act, including the 25C, 25D and 45L tax credits.
