Greetings,
I acquired a redwood barrel hot tub in pieces. The existing drain in one of the floor boards appears to be a stock thick walled 1-1/4″ steel sink drain w/o overflow with fine threading. I want to connect this to PVC Street elbow and PVC pipe with PVC ball valve terminus. Is there a bushing that converts fine threads to pipe threads? If so, who has it?
If not, any suggestions in a drain fitting ( floor board is 1-3/4 thick)
Thank you in advance
![](https://images.finehomebuilding.com/app/uploads/2024/07/17093454/01232564-sited-in-the-trees-thumb-16x9.jpg)
This home features dramatic interior spaces enhanced by views of the surrounding trees and stream.
If nobody has your answer here, check out :
https://terrylove.com/forums/index.php
No kidding, if they don’t have the answer, I’d be surprised.
