I’m about to begin refacing kitchen cabinets, red oak veneer over stained red oak cabinets. Will first apply water-based contact cement over carcase before applying peel-n-stick veneer. Is there any need to remove/strip existing stain from carcase before applying contact cement? Would appreciate any info. Have carefully read “Refacing Cabinets” book, an excellent how-to, but didn’t see any reference to veneer-on-stained cabinets. Did I miss it, or is it a non-issue? Thanks.
![](https://images.finehomebuilding.com/app/uploads/2024/07/16103615/01232548-cost-of-building-house-feature-thumb-16x9.jpg)
Understand the difference between estimating and cost planning, and don't let your sweat equity evaporate into budgeting mistakes.
Vic,
Joseph Fusco
Vic,
I don't understand (have not read that book) why you use contact cement with peel and stick veneer. My understanding of the chemistry of contact cement is that is ineffective unless it is joined to itself. But a true contact cement will work as well, if not better, on a smooth surface rather than a rough one, and so you could save a lot of work by not sanding the cabinets, -just be sure they are free of oil or grease with a thorough cleaning and solvent wipe.
Vic,
Joseph Fusco
Joe,
Thanks for your response. I'll do a bit of sanding, as you suggest. I couldn't download your first message, but the second was loud and clear.
Vic,
Joseph Fusco
Applying veneer with contact cement is a mistake. The job will look better and last longer if you simply paint the cabinets instead.
I'm about to begin refacing kitchen cabinets, red oak veneer over stained red oak cabinets. Will first apply water-based contact cement over carcase before applying peel-n-stick veneer. Is there any need to remove/strip existing stain from carcase before applying contact cement? Would appreciate any info. Have carefully read "Refacing Cabinets" book, an excellent how-to, but didn't see any reference to veneer-on-stained cabinets. Did I miss it, or is it a non-issue? Thanks.
I just finished refacing some assemble yourself cabinets I bought at a big box as I wanted real maple instead of foil on the ends of the cases. I followed Herrick's book and was pleased with results if not the time it took. If you do not buy pre-finished veneer, you might try a waterbased varnish called Varathane. I am told it holds up well, it applies fairly easily, drys fast, and cleans up in a breeze.
Good luck
Dennis
