refinishing red oak flooring
toolszeke | Posted in General Discussion on June 9, 2009 06:33am
I am about to refinsh oak flooring in my home that originally had a wax finish.  (Bruce Flooring 1980’s).  Even if thoroughly sanded I am told that it is risky to refinish the flooring with anything else than a wax finish.  Is there any finish or steps that I can take to insure proper adhesion of  a new finish.  Would a coat of sanding sealer help?  Any suggestion would be appreciated.  I am hoping that I don’t have to refinish with a wax finish again.
Edited 6/9/2009 11:34 am ET by toolszeke
  1. YesMaam27577 | Jun 09, 2009 07:16pm | #1
    Are you sure that the finish was wax? That would be really uncommon for a 1980's floor, unless it was installed and waxed by the homeowner.
    In any case -- if there is wax that has gotten into the wood, then you'll have a hard time applying anything and getting good result. Wax has a habit of repelling most finishes.
    There are some lacquer products, for which you can buy and additive that will help.
    Good luck.
    Politics is the antithesis of problem solving.uer
    1. toolszeke | Jun 13, 2009 05:37am | #4
      Thanks for your advice. Bruce made a pre-finished floor in the 80's that supposedly had a wax finish. For regular maintenance they recommended applying paste was to the floor twice a year.
      As an experiment I started on my 75 square foot foyer. I sanded the floor and hand scraped and sanded the dust grooves between the boards. A flooring supplier (I wasn't the first person that came to them about this) said that it the finish fails it should do so with 4 or 5 months. I plan to follow your advice and use a lacquer. I also am going to try a small area where I will first apply some Kwik Poly before I apply the topcoats. I guess the worst thing that can happen is I have to tear out the flooring and install new flooring. I'll let you know in a couple of months how it turns out.
      Thanks again
  2. rez | Jun 09, 2009 07:35pm | #2
    Vulkem?
      IMERC | Jun 09, 2009 10:43pm | #3
      that would be interesting....
      give it a try and get back to us...
      WOW!!! What a Ride!
