refinisihing formerly linoleum floors…
You can try some of the solvents designed for mastics. Such a Bean-e-doo.
William the Geezer, the sequel to Billy the Kid – Shoe
Only "several" layers?? My parents removed, IIRC, 13. Found a dead mouse about 5 layers down.
Try Goof Off.
Be carefull, some of that mastic might be asbestos laden!
Abatix.com has a goo quality mastic remover. No sanding, it just wipes up with a paper towel.
Tu stultus es
Also a CRX fanatic!
Look, just send me to my drawer. This whole talking-to-you thing is like double punishment.
I'd also worry about the possibly of asbestos.
I did some stairs a few years ago, and just worked the steps with a scraper. hard work but cheap and fume free.
I removed a brown, felt-like pad that was glued under 1930s linoleum with water. Nasty smell and very messy work. Had to shop-vac the gunk out of the cracks.
heat, then paint thinner, and a respirator
I did a job like that the early part of this month. I had my MultiMax and used the scraper blade that was sold separately to scrape of the excess tar paper. What was left was easily sanded.
I included a video of it.
Some of my day
Start with HOT water. You'd be amazed at the number of people who have come across this problem and found out that hot water and a scraper is all that is needed. Saturate the black stuff, let it sit a couple of minutes, then scrape. You can also use old towels soaked in hot water, and lay them on the black stuff.
