I have some slate work to do and am concerned about grout, specifically about cleaning up after I grout the stone. What is a suggested release agent to ensure that the grout doesn’t bond to the surface of the slate tiles?
Listeners weigh in on Brian’s haunted showerhead and ask questions about covering overhangs with trim coil, sealing air leaks, and how to partially finish a basement.
I have heard that a silicone sealer for the tiles is available and recommended before you grout to seal the tiles. Anybody else have a better idea???????
I recently installed a cleft face slate in my shower and used a water base grout release. It worked. The stuff came off as I cleaned the grout (I also washed the slate with water after the grout had set). What I liked about the product was that I could then select the type of sealer after I grouted the tile (I then used a stone enhancer/sealer that brought out the grain and color of the slate).
thanks. What brand was the product you used?
Sorry,
Aqua Mix grout release and the make a stone enhancer (solvent based for hard stone and water based for softer stone)
Here is the link for the grout release.
http://www.aquamix.com/gr.htm
