Release agent for wood concrete forms?
Danno | Posted in General Discussion on July 4, 2009 12:33pm
My brother is making porch steps or some such and wants to know what you use to keep the concrete from sticking to the wooden forms. I told him that although it is probably not too “green,” as far as I know, you use (used) motor oil. Anything else, or better, or less ecologically polluting? I told him I supposed that if he could find used fryer oil from a fast food restaurant or salad oil or even linseed oil, those would work. I suppose you could use mink or emu or coconut or…but I think the price might be a little high! ( I suppose you could rub the forms with your hair, but I hate getting splinters in my scalp!)
  1. Hudson Valley Carpenter | Jul 04, 2009 01:00am | #1
    One such product.
    http://www.bioblend.com/content/view/96/86/
    shelternerd | Jul 04, 2009 01:40am | #2
    Peanut butter! Smooth, not chunky.
    m
  3. frenchy | Jul 04, 2009 02:29am | #3
    wrap with plastic  (poly)  then reuse the poly for other uses.
    1. CRF | Jul 04, 2009 03:02am | #4
      I always spray the inside of form with diesel from a weed sprayer just before the concrete goes in the form
      1. Danno | Jul 04, 2009 03:11am | #5
        Thanks for the replies--I re-read my brother's email and it is a small stand he is making (not sure what size exactly), but not steps as I somehow pictured. So probably plastic film would be quick and easy and relatively non-hostile to the environment.
        1. brownbagg | Jul 04, 2009 04:14am | #6
          use vetable oil, how can it be harmful to the enviroment, its vegatblles
          1. enrare | Jul 04, 2009 06:54am | #9
            I second the veggie oil, I used the cheap store name brand.
      2. DoRight | Feb 01, 2013 02:12pm | #11
        How saturated does the form need or not need to be?
        How saturated ....?
        1. DaveRicheson | Feb 03, 2013 09:18am | #16
          Saturation
          We generaly just sprayed one coat of release oil on new or old forms. If for some reason we had to use regular playwood we would do a double  coat of oil.  Form board has more plys than standard plywood.  I don't know why, but the less dense regular plywood seemed to drink the oil much faster then form board and it took to coats to make sure there weren't any dry spots.
          Our old forms had been used so much that I think a third of the weight was from the oil in them. On large jobs we would assign one guy to spray or roll form oil on the forms before we started setting them.  I've seen crews spray them after settint, but was tought that was wrong because it also got oil on the reinforcing steel and it ran down onto the footing.  The oil is suppose to be a bond breaker,so getting on stuff you want the concrete to stick to was a no, no.
    2. Kevin_D | Feb 01, 2013 03:19pm | #13
      You can use boards with melamine too.
  4. KenHill3 | Jul 04, 2009 04:29am | #7
    My GF and I have been casting concrete pavers, ply and 2x2 formwork. We've been using canola oil- seems to work just fine.
    Jeff_Clarke | Jul 04, 2009 06:24am | #8
    Use spray Pam - it works great.
    Do not use automotive oils - a small amount can contaminate a lot of water.
    Edited 7/3/2009 11:25 pm ET by Jeff_Clarke
  6. chipf | Jan 31, 2013 10:44pm | #10
    Quick/Cheap Fix to stop concrete from sticking to forms
    I recently formed and poured 5 stairs and a 4x5 landing with concrete.  I went to the internet to find solutions.  As many noted, I have seen the "pros" spray diesel fuel to do the trick. This definitely works but for such a small job, I did not want to buy diesel/container and ruin my garden sprayer.  Instead, I bought a spray can of Thompsons waterseal  for $5 at Lowes and sprayed all the surfaces of the wood forms.  It worked like a charm and I didn't have any problems getting the forms to release.
    Hope this helps!
  7. Kevin_D | Feb 01, 2013 03:18pm | #12
    In addition to the replies above:
    I know they use release agent for stamping etc. The concrete guys calle it "Bubblegum" because of the smell. Most concrete places have it.
    If you google "Form Release Agent" you'll come up with a variety of brands you can buy commercially.
  8. DaveRicheson | Feb 01, 2013 04:06pm | #14
    Form Release Oil
    He can get a gallon of form release oil for about $8 at any concrete supply.  Spray ,wipe or brush it on. For a small project a gallon is more than enough, so he will likely have enough left for another small job.
    Not much danger of polution with form oil unless it is spilled or sloped arounf indiscremently.  Most of it soaks into the form where it is suppose to be.  We used the same forms for years of foundation work.  On small jobs we sometimes didn't need to oil the forms. They were so saturated from previous jobs that it wasn't needed.
    If he uses MDO forms, as I sometimes do for small precast work, he can wipe them with a layer of petroleum jelly.  It works great on the really smooth surface of MDO, where oils tend to just roll off.
  9. DaveRicheson | Feb 01, 2013 04:06pm | #15
    Form Release Oil
  10. whsmith | May 31, 2016 01:49pm | #17
    The data sheet has moved for the BioBlend Concrete Form Release
    http://www.bioblend.com/pages/product-data-sheets
    1. calvin | May 31, 2016 06:58pm | #18
      Well....
      It has been several years since 2009.
      some things take time.
Mortar for Old Masonry
