remodel bathroom w/ skylight and fan ?
cut | Posted in General Discussion on January 16, 2004 04:57am
Reduing a bathroom.  Homowner wants a sky light I recomend an exhaust fan.  What are the goods & bads for each or both?
  1. MojoMan | Jan 16, 2004 05:03pm | #1
    Go with both. Here in Massachusetts, a fan is required in all bathrooms whether or not there is a window. There will be plenty of times when the fan is used when the skylight won't be open.
    Al Mollitor, Sharon MA
  2. davidmeiland | Jan 16, 2004 06:11pm | #2
    The fan is a must and a timer switch is a nice way to control it. If you do an operable skylight you are required put the plumbing vent at least 10 feet from the nearest corner of the skylight. Last two bathrooms I did had Velux motorized skylights with rain sensors. Love 'em and would not remodel without.
    1. archyII | Jan 17, 2004 03:37am | #6
      Another nice control is a humidistat build into the fan.  Comes on when you need it and then shuts off when the moisture is gone.
    2. WorkshopJon | Jan 19, 2004 07:30am | #8
      "you are required put the plumbing vent at least 10 feet from the nearest corner of the skylight."
      Dave,
      How do you do that in the upstairs bath of an older cape? Typically those baths are not that big.
      Jon
      1. davidmeiland | Jan 19, 2004 07:51am | #9
        Run the vent up into the roof framing or attic space and then run laterally until you're 10 feet away.
    BillHartmann | Jan 16, 2004 09:23pm | #3
    Why not both? Why does he want a skylight? They are not interchangable devices.
    However, you can get tubular skylights that have an exhaust fan in them, I THINK.
    Edited 1/16/2004 3:25:25 PM ET by Bill Hartmann
    1. cut | Jan 17, 2004 02:02am | #4
      I noticed the tiles falling off the mildew walls, the paint peeling and the ceilling sagging, really hanging loose.  I think they need an agressive moisture control, such as a high quality fan.
      The customer is improving the bath and somebody told them that a skylight would take care of the moisture.  They like that idea now, but I think they still need a fan.
      The bath is getting a bit of work; it's being cut into the bedroom, the sink moved, the toilet moved, shower window reduced as well as moved up and a face lift.
      Id like to keep it quality and practicle.
      1. ronbudgell | Jan 17, 2004 02:24am | #5
        I installed a skylight in my own bathroom some years ago. It added a lot of light and allowed me to eliminate a window from the tub/shower, a guaranteed rot spot.
        On the other hand, I used to get icy cold drips of condensation on my head when I had a shower in winter.
        Two choices: quit having showers in winter or prevent steam from getting to the skylight glass, so I installed a horizontal sheet of lexan in the skylight well at ceiling level.
        Skylight wells tend to collect condensation and deteriorate fast so i strongly recommend isolating it from the bathroom or giving it its own ventilation like a supply duct from the ventilation system if there is one.
        Ron
  4. fortdh | Jan 17, 2004 06:29am | #7
    Kutz, there is a new skylight available filled with a gel for very high R-Value. It's pricy but may prevent "Raindrops Keep Falling on my Head" from becoming their theme song. Regardless, they have to solve the humidity problem, and a picture window in the sky won't do it. Paul
    Energy Consultant and author of Practical Energy Cost Reduction for the Home
  • xoxo test post 3
  • xoxo test post 2
  • xoxo test post 1
