Removable posts for a canopy/awning?
tab1 | Posted in General Discussion on May 9, 2005 04:39am
I’m thinking about attaching a canopy/awning (about 20×20) to my house to protect a couple of vehicles from sun/rain/birds. Two of the corners would be attached to the house but 2 would need to be supported by freestanding posts. This structure needs to be technically removable to meet zoning regs. I’ve had 2 ideas about anchoring the posts: 1. Drive maybe 24″ of 1 1/2″ steel tube to ground level, then put 1″ (?) steel post into that. (Not sure how well they would fit.) 2. Place steel post over something, like a 42″ concrete form stake (?).
Any other ideas or past experiences with similar, or thoughts on awning material and source, would be appreciated.
Thanks.
Thon
  1. rez | May 14, 2005 06:21pm | #1
    bump
    This is purely a case of alien identity
  2. rez | May 19, 2005 04:27pm | #2
    No luck here.
    You may want to try your question over at the JLC forum.
    Cheers.
    http://www.jlconline.com/cgi-bin/jlconline.storefront
    "I can't say I was ever lost, but I was bewildered once for three days."
  3. GregGibson | May 19, 2005 05:07pm | #3
    Tab,
    The only thought I've had is the anchor system that came with my son's in-ground basketball goal.  Pretty much just a hollow plastic sleeve which was surrounded with about 1,000 pounds of Quik-crete.  The oh, probably 5 inch diameter (concrete-filled) goal post slipped into the plastic sleeve.  Before filling it with 'crete, of course.
    On the plus side, when the kid leaves home, I can eliminate the post pretty easily.  The plastic sleeve is just below grade.  So in your situation, the posts could be slipped out for mowing, etc.
    We've got core-drilled volleyball net post sockets similar to this in the gym floor at the church gym.
    Greg
    1. tab1 | May 20, 2005 03:53pm | #4
      Thanks.
      1. BowBear | May 20, 2005 07:21pm | #5
        Are guy wires a possibility? Why not two posts set on concrete bases with two guy wires each clipped to deadmen bureied in the ground?Simple, light weight and easy to assemble disassemble.An ex-boat builder treading water!
        1. jarcolio | May 20, 2005 07:42pm | #6
          look at what awning companies use -- they have a flat plate that attches to the pattio about 4" in diameter and the foot of the awning leg has a spring loaded latch that you can move with your foot as it attches to the 4" plate - very, very simple and cheap
