removal of plastic window mullions
knarf | Posted in Construction Techniques on March 25, 2005 05:55am
I bought a lovely 16 year old house near Noosa. Queensland, Australia which has windows all around – mostly floor-to-ceiling. Unfortunately about half of them have plastic strips glued to the inside & outside of the glass to imitate mullions and create the image of many (about 700) window panes.
Does anyone know of a technique or solvent that will help remove these things? I’ve tried all the household products but its like they’re welded on.
Frank in Oz
  1. FastEddie1 | Mar 25, 2005 06:58am | #1
    maybe a careful appl,ication of a heat gun?
    IMERC | Mar 25, 2005 10:07am | #2
    If you use a heat gun be very careful. Spot heating the glass is most likely to break it. Scrape the bulk off with a razor amd then use conventionl solvents on the glue.
    Start with paint thinner and work your way up through lacquer thinner and the more aggressive ME's.
    WOW!!!   What a Ride!
    Forget the primal scream,  just Roar!
    1. IronHelix | Mar 25, 2005 01:32pm | #3
      Also you may find that vegetable cooking oil, WD-40, gasoline, or diesel may also give good results.
      Avoid the heat gun as suggested!
      .......................Iron Helix
  3. sledgehammer | Mar 25, 2005 02:24pm | #4
    I have removed miles of grilles off new windows when there is a manufacturer error.
    Most are put on with a double faced tape that is easier to remove when cooled. I use a horse hoof trimmer and soapy water, it's a very slow process. Recently removed the grilles on 160 sash done 6 over 6, it took about 20 min per sash... do the math. BORING!!!! And no, it's not perfect as I did break 1 of those sashes.
