removal of tar-like linoleum adhesive
GreggU | Posted in Construction Techniques on July 8, 2008 08:54am
I recently pulled up two layers of vinyl and linoleum floor covering in my bath, expecting to restore the original 1×4 t&g fir flooring. It seems to be in good shape, but there is a heavy layer of some sort of asphalt adhesive all over the floor. I have tried liquid paint removers and solvents. All they do is soften the tar a little. I’m also afraid that with he solvents, I’ll dissolve it enough that it will soak into the wood more. Scraping does not work. I do not want to use caustic paint removers as that will stain the wood black.
Does anyone know how to remove this stuff cleanly other than using up $600 worth of sanding belts?
Edited 7/8/2008 2:09 am ET by GreggU
  1. KenHill3 | Jul 08, 2008 10:07am | #1
    I'm almost certain someone will come along with the correct answer here because it is a 'common' problem.
    Something in the far reaches of my brain is saying dry ice, maybe something with water...........
    ......sorry, best I can do.
    1. BryanSayer | Jul 08, 2008 04:19pm | #8
      There is one adhesive substance that comes up with hot water. Soak a towel in hot water, wring it out some so that it is not dripping, and lay the towel on the adhesive for a couple of minutes. See if it softens, and if it does, scrape it up with a wide pull scraper.If that doesn't work, try dry ice in a plastic bag. Set the bag on the adhesive for a minute or two, and then scrape with a wide pull scraper.Watch out for nails.
  2. sledgehammer | Jul 08, 2008 01:52pm | #2
    Alot of those old adhesives and tiles contained asbestos. Sanding may not be a good option.
    1. wane | Jul 08, 2008 03:25pm | #3
      "Scraping does not work"
      actually I'm thinking that's your only option, but you need something more like a wide chisel or hand plane blade and push it, not a pull type scraper.  You want to take just enough of the wood not to have to mess with the adhesive, can we say multimaster??
  3. smllr | Jul 08, 2008 03:25pm | #4
    Depending on its type, warm water may help loosen the adhesive. I was able to remove the adhesive on one of my floors using warm water, Mean Green, a 3M scouring pad, and a lot of elbow grease.
    Steve M.
  4. darrel | Jul 08, 2008 03:28pm | #5
    Order a sample bottle of 'bean-e-do' from Franmar chemical and see if it works:
    http://www.franmar.com/
    We used the stuff on tile mastic in our basement and it worked wonderfully. It's soy based, so non-toxic.
  5. 2weekstops | Jul 08, 2008 03:46pm | #6
    just had to remove linoleum from a subfloor- never easy,   a good sharp chisel-  SHARP  - will do the job,  be patient there is no real easy way .  In the bath this might take a couple of hours.  Sorry but its called work, you cant look it off of there
    1. nbrauner | Jul 08, 2008 03:56pm | #7
      I encountered the same problem in my renovation.  What worked really well was a citrus based tar removal solvent.  The brand escapes me but and internet search should turn up the product.  It turned the adhesive into a gooey liquid which scaped up fairly easily.  There was still a film on the wood which required a lot of sanding.  I also had the tar adhesive tested for asbestos which came out negative.   Good luck its worth it the floor look great.
  6. reinvent | Jul 08, 2008 04:53pm | #9
    How about a block of dry ice. Freeze a section then chisle it off. Will keep you cool during this hot weather.
  7. Sasquatch | Jul 08, 2008 05:30pm | #10
    Fein Multimaster with scraper?
