Remove fireplace stone-cover w/drywall
RRooster | Posted in General Discussion on March 18, 2007 09:54am
I have a customer who is considering having me remove the stone and mortar from their fireplace and cover the wall with drywall making a smooth drywall transition across the entire wall.  The fireplace has a propane insert (Country Stoves) in place now and it will be re-installed when the proposed project is complete (time frame for project is Fall ’07).  I will also be installing a new mantel of their choice.
Any issues here to consider before I price this thing?  Like NFPA clearances?  Combustible construction materials in proximity to the insert?  Thanks.
For good new rock music, click on: http://www.wolfmother.com
  1. rez | Mar 22, 2007 01:37am | #1
    Greetings R,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
    every court needs a jester
  2. woodroe | Mar 22, 2007 01:58am | #2
    I don't think you will have any problem doing what you're proposing. However, I would look at the MFG's installation instructions for the stove and make sure you are following their recommendations.
      RRooster | Mar 24, 2007 05:56pm | #3
      Thank you rez and woodroe.  I have uncovered info by web searching and phoning and stuff.  Using all resources, you know.
      Rez, bump king.
