Removing 1940’s rubber tile glue
EAC2008 | Posted in General Discussion on July 9, 2008 04:54am
I was asked by a church where I will be installing a kitchen in a community area and day care area in their basement to help with the removal of a rubber style glue on the floor. Originally I advised them to cover up the asbestos tile but they insisted on removal. The asbestos abatement company did a decent job removing the tile but left the glue which has to be removed before the new floor can be installed. The floor will be a combination of tile, prefinished hardwoods, and hi-tech rubber. The floor contractor wants nothing to do with the glue removal.
I’ve already tried burning and scraping but the fumes and smoke was unacceptable. I am considering sandblastng and have someone coming in to test that possibility. There is abour 3200 sq.’ of floor.  Any ideas guys?
  1. plantlust | Jul 09, 2008 04:58pm | #1
    I've used a heatgun. Melt, wait, then scrape.
    Somewhere in this forum is a thread where someone recommended using dry ice. Makes the stuff brittle, so you can easily scrape it off.
    Temp to hire position starts 14 July.
      jagwah | Jul 09, 2008 05:08pm | #3
      Dry ice sound interesting, like putting an ice cube on gum to harden it for easy removal.
      Does the cold you think, brittle the concrete surface, encourge spalling if it's weakened already.
    jagwah | Jul 09, 2008 05:04pm | #2
    I'm curious because sometimes that adhesive is asbestos based as well. Did your abatement company assure you the glue was non-hazardous? If it's certified to be safe than there are a number of ways but I wouldn't use flame, safe or not the fumes are bound to permeate the area and reak for a while.
    Heavy scraping with razor scrapers then sanding with floor sanders maybe even grinding the surface might be best if it's safe to do so.
    There are some solvent orange based removers like
    http://www.grs-systems.com/item98.htm
    I don't have experience with this type but there are many products waiting to be Googled.
  3. sandalboy | Jul 09, 2008 07:32pm | #4
    My wife and I restored a floor in a 100 year old hotel. It had beautiful mosaic tiles underneath several layers of flooring. It took about a month to do about 1200 square feet. We tried all kinds of things, and none worked great. I'm not sure what the adhesive was, but most of it was a black tar like substance. We alernated between using a heat gun and chemicals as we got tired of one or the other. One thing that was definately helpful was a heavy duty floor polisher. The one we have is a low rpm one, not the higher speed buffing kind. It weighs about 100 lbs and takes the round scrubbing pads. 3M/Scotch makes many different levels of abrasiveness in these pads. We were using the most abrasive ones, which were like steel wool with grit fused to it. Stuff like you might clean a barbaque with. These were the most expensive ones also, like $10 or $15 each. We probably used about a dozen of them.
    We would use the machine over the chemically softened adhesive. We used various paint strippers, none of which worked great. I would not want to go through that again just to put new flooring over it. If I were flooring over, I be looking into putting a skim coat of something over the whole thing.
    1. EAC2008 | Jul 10, 2008 12:26am | #5
      Thanks all for the suggestions. I'm going to try plastic pellet blasting the the stuff in a day or so.; will let you know how it turns out. With 3200 sq. ft. the heat gun would be exhausting and one of my guys would probably turn a real gun on me if he had do that for a couple of weeks. The dry ice though is intriguing and is my partners choice. He's a big S. King fan and likes the ambience we could create in a 200 yr. old Church. Thanks all,
      Ed     EC Painting and Remodeling.
                Providence RI
  4. k1c | Jul 10, 2008 02:27am | #6
    There is issue with the glue as well for asbestos.  Usual advice is not to sand or blast where there would be fine dust.  I would have this tested and not take the responsibility later if asbestos is found again.  Hope this helps.
    1. EAC2008 | Jul 10, 2008 08:02am | #8
      Adhesive has been tested by city, and state with negative results on both tests. Since both tests were negative the asbestos removal contractor felt his part of the was done. Thanks for the concern.
    rjw | Jul 10, 2008 02:36am | #7
    As to have already noted, there is a good chance the "glue" (likely aka "cutback adhesive") has asbestos - although I would have expected the asbestos abatement company to have tested it.
    See, e.g.: http://www.fcimag.com/CDA/Archives/0a10a398a9c5e010VgnVCM100000f932a8c0____
    Remember Mary Dyer, a Christian Martyr (Thank you, Puritans)
    http://en.wikipedia.org/wiki/Mary_Dyer
    May your whole life become a response to the truth that you've always been loved, you are loved and you always will be loved" Rob Bell, Nooma, "Bullhorn"
  6. BryanSayer | Jul 10, 2008 04:48pm | #9
    There are some old adhesives that come up with hot water, as in as hot as you can get it. Try a small area first. You can use an old towel soaked in hot water and let it set for a few minutes, then scrape with a floor scraper. If it works, and you won't damage anything, flood an area with hot water then scrape.
    You might also look at soda blasting.
