Removing a cabinet filler
Satch | Posted in Construction Techniques on October 8, 2002 03:45am
I have to replace a filler at the end of a cabinet run. It was glued in place with ordinary white glue.Any suggestions on how to break the seal without damaging the cabinet?
  1. geob21 | Oct 08, 2002 04:07am | #1
    Glued?
    Razor knife and hammer, the end of the cabinet has a finish on it and the glue should not have bonded well. if it's ordinary white glue.
  2. MisterT | Oct 08, 2002 04:10am | #2
    take the cabinet down and remove the door and the hinges if they are in the way and clamp a straight-edge to the face of the cabinet and saw it off!
    put some tape on your saw base and use a sharp 40-tooth blade
    Mr T
    Do not try this at home!
    I am a trained professional!
  3. Piffin | Oct 08, 2002 04:48am | #3
    A lot of these glues are heat sensitive. Like ggglazing, they will get gummy again under a heat gun. That might not help the finish though. If it's painted, you are going to have to touch up anyway.
  4. RW | Oct 08, 2002 05:17am | #4
    White vinegar. It will soften it up enough to break the bond, and you can rub the residue off.
