Removing a lally column
MRmike | Posted in General Discussion on September 24, 2005 09:32am
I’ve got a single story house with a basement.  The main floor is supported down the center by a 3×7 inch steel I-beam which sits atop 3″ steel columns on 8 foot centers. I’d like to remove one of the columns to make room for a pool table and I’d prefer not to have the floor cave in.
I’m thinking of sistering a second 16 foot I beam between the remaining columns or perhaps just reinforcing the vertical web of the existing beam by welding a 1/4″ x 6″ plate along that span.
Is this do-able or should I just buy a smaller pool table?
  1. seeyou | Sep 24, 2005 10:27pm | #1
    Greetings Mike.
    Try posting this in "general discussion" and you'll likely get more response.
    Birth, school, work, death.....................
    1. MRmike | Sep 25, 2005 12:29am | #3
      Thanks, I will.  Fortunatly I'm much better with a hammer than a computer!
  2. Link | Sep 24, 2005 10:35pm | #2
    I think you need to hire an engineer.  He might suggest you add 2 new I-beams.  One on either side of the existing beam.  Without an engineer actually looking at it you would be foolhardy to do anything.
