Removing an old Propane line
spikemdh | Posted in General Discussion on September 17, 2020 12:00pm
We use to have a modern gas fireplace that ran on propane. It was removed but the old line remains. Can I remove this myself? Is it safe? There is no longer a propane tank, the end of the line that connected to the tank is open to the outside and just hanging out the outer wall. I want to remove the whole line. I able to reach the majority of the connections to disconnect, but I will have to cut a portion of the line. Can this be done?
  1. mgmahan | Sep 17, 2020 02:44pm | #1
    If there's no gas attached, go for it.
    unclemike42 | Sep 17, 2020 04:02pm | #2
    You can cut the line (probably copper) with anything you like that you find will work.
    You might want to find a scrap place if you have a good length, the scrap price might make it worth a short trip.
    1. mgmahan | Sep 17, 2020 04:23pm | #3
      Most likely not copper. I’ve seen cu gas lines on rare occasions but it’s not legal.
  3. firedudec56 | Sep 17, 2020 09:00pm | #4
    use a tubing cutter rather than a grinder or saw and you shouldn't have any ignition issues if there happens to be any propane left - also, propane is heavier than air and will "sink" so vent up & out
    good luck
