Removing basement windows set into wall
| Posted in Construction Techniques on September 27, 2002 02:33am
I am planning on a small addition to a house.  I will have a poured frostwall foundation poured.  Where one of the new poured walls meets the existing poured wall there is a steel-framed basement window.  I am assuming that this window will need to be removed, and forming installed prior to pouring to form a return where the window was.  My question is how difficult is it to remove these types of windows that are set into the poured wall?  Thanks for your help!
  1. Piffin | Sep 27, 2002 06:53pm | #1
    The window unit itself is easy.
    Then you have a meatl buck frame that is almost parto f the concrete wall.
    Eye and ear and hand protection.
    grinder
    sawzall with metal demo blade
    big hammer
    cold chisles
    three hours time
    -OR-
    Protection plus rent a demo hammer and an hour of time
    1. marko509 | Sep 29, 2002 04:23am | #3
      Thanks for all of the great responses!  Turns out that it took about 2-1/2 hours to remove, and some of that time was spent removing some drywall on a boxed out ceiling in the adjacent basement room.  After removing the window unit itself, I ended up cutting the frame in half on each side and prying it out of the concrete with a demo bar and hammer.  Thank God for Sawz-All's!
      One thing I noticed while doing this is how the original contractor built the floor system.  There is 1" styro on the outside of the foundation, and the builder let the sill plate and rim joist hang over the top of the foundation to make the edge of the rim flush with the styro.  This places 2/3 of the rim joist (along with the load bearing exterior wall and roof system) hanging over the foundation.  Around the windows the sill is cracking from the weight and the top of the rim is tipping out from the house.  This house is 6 years old and was built by (according to the owners) a reputable contractor.  The homeowner is a mechanical engineer and after some thought felt that it'd be okay, although I feel that this is based on how much it would cost to fix the problem.
      What do you all think?  I say that if they would've doubled the rim or atthe very least installed blocking over to the next parallel joist it would probably be fine.  Thanks for your input!
      1. Piffin | Sep 29, 2002 05:20am | #4
        Ugh!
        Blocking heap big good stuff..
  2. MarkH128 | Sep 27, 2002 07:31pm | #2
    Giant size slide hammer will rip em out faster than cuttin em out. Can get messy though.
