Removing construction adhesive
MRockwell | Posted in Construction Techniques on November 16, 2002 06:39am
Needing a little advice on the best way to remove construction adhesive from pine.  I have a job that involves removing pine 1x trim on a wooden garage door, and replacing it with a wider piece of trim.  The existing trim is glued to pine v-groove.  I have already removed the trim and there is still construction adhesive adhered to the v-groove.  I need a flat surface to glue the new trim to the door.
One possible way I was thinking was to use a heat gun to soften the adhesive and scrape it off.  But would a heat gun burn or damage the pine underneath?  I want to avoid using solvents, sounds messy and the door will have a stain finish applied.  Pretty sure solvents would mess up the stain application.  Any suggestions?
Mitch
  1. Snort | Nov 16, 2002 07:11am | #1
    Don't take this the wrong way, but sometimes you've got to know when to take it easy. This is a garage, where cars are parked, right? Why has it all got to look puuurfect? Rolls Royces? Ferrarries?
    It's okay, I can fix it!
    1. MRockwell | Nov 16, 2002 08:49pm | #2
      I suppose it's because I was selected to do a first rate job, not hack it up.  And the fact that it's an expensive home.  I do get your point, it's just a garage.  But when the garage doors are a focal point of the house, it's important to me to make them look good.  Maybe I dind't make my first post clear by saying that these are exterior facing overhead doors that will be seen when someone drives up to the house.
      1. Snort | Nov 22, 2002 06:01am | #5
        I have seen something like Liquid Nails Undoo...will look farther for it It's okay, I can fix it!
  2. MarkH128 | Nov 17, 2002 02:42am | #3
    Methylene chloride paint stripper. People stain after using it all the time. Be sure to follow directions, its explosive, and SOME say a health risk.
  3. snider77 | Nov 17, 2002 05:23am | #4
    what is with subfloor adhesive on exterior trim?  I work with a guy who uses it everywhere.  I feel like it is overkill and a reel pain when someone tries to remove whatever was adhered with it.  am I right or is this a common practice to use subfloor adhesive whenever possible?
    -z
