I purchased copper flashing to make some lamp shades and I am told that there is a coating on the flashing to keep it looking new. I want it to oxidize naturally ( but as soon as possible). What is the finish on the copper and how do I get it off.
Thanks a lot,
Rand Strausser
![](https://images.finehomebuilding.com/app/uploads/2024/08/12143051/FHB-Pod-644-Segment-3-thumb-16x9.jpg)
Discover the messy truth about removing painted popcorn ceilings in this Fine Homebuilding Podcast segment.
Most likely lacquer. Try steel wool. There was a thread here some time ago about accelerating the accumulation of "patena" on copper. Some folks apparently had good results with urin but I don't recall how it was applied.
*vinegar and steel wool..(000)cider vinegar works good..
*...first thing you gotta do is unplug the lamp.
*acetone.
*We used to remove the lacquer on Army belt buckles with fingernail polish remover, which was basically acetone. Reason was that nail polish remover was readily available at the PX. I tried this recently when cleaning up an old laundry boiler and found it didn't work well, because today's Cutex is weaker and contains hand lotion stuff. I also found with the copper boiler that using any abrasive pad, such steel wool or a 3M pad will require that you get the scratches out afterward, so I'd go pure chemical, avoiding mechanical.
Thanks a lot,
Rand Strausser
