Removing Mortar from Plywood Subfloor
| Posted in Construction Techniques on February 6, 2004 11:56am
Can anyone give me advice on the best way to replace a kitchen tile floor? I tore up the old tiles easily enough, but a significant amount of mortar remains on the plywood subfloor. I don’t want to put down another layer of plywood because it will be too great of a height difference with adjacent floors. Is there a good way to remove the mortar or will I have to replace the subfloor?
– Rick
    EricPaulson | Feb 07, 2004 12:38am | #1
    If the remaining mortar is REALLY STUCK AND the Floor system is sound and meets requirements for tile installation; I have skim coated a floor like this with thinset after applying a good bonding agent. You don't need to get it perfect because you will be using a notch trowel and possibly back buttering the floor tile anyway.
    I spent a day screwing the UL down first. That is why the original job failed.....flexing of the UL due to improper/lack of fastening.
    Good Luck
    Eric
  2. hammerelbow | Feb 07, 2004 05:18am | #2
    We just did a remodel on a 1946 ranch  and ripped up about 700 sq of terra cotta on a mud base. We couldnt get the cement offso we pulled up the subfloor and replaced it. It was a hell of a job. Somebody went and put screws in the floor for some reason. The end result was worth the effort. The new kitchen went in a lot nicer because of the new floor. One of those things you cant forsee at the start of the job.Homeowner ended up paying for it and their both happy.
    1. rsfeynman | Feb 07, 2004 07:30am | #3
      I think I'll try a floor sander and and use a cheap fan to blow the dust out a window.
      Sphere | Feb 07, 2004 05:06pm | #4
      That reason is they are better than nails alone..fewer squeaks.
      Go Stab yourself Ya Putz! Ya think I Parked here?
      Edited 2/7/2004 9:08:13 AM ET by SPHERE
      1. hammerelbow | Feb 07, 2004 05:33pm | #5
        I was just being  sarcastic. I guess you had to be there. They were the old #10 straight slot screw with the big head on them. The only thing that realy made the job hard.
          Sphere | Feb 07, 2004 05:42pm | #6
          they are fun. rebuilding pipeorgans from mid 1800's , they were all like that..up to # 20's...used a brace and bit to remove them..brass no less. Still got brass slivers in my hands!!
          Sarcasm..hmm..who'd a thunk it?  don't come out well in typeing. I mis understood..sorry.
  3. andybuildz | Feb 07, 2004 05:45pm | #7
    If the cement doesn't stick up "too" far you should be able to trowel out thinset over it. Then I'd lay some 1/4" CBU over that screwed down.
    Be screwed
                   andy
    My life is my practice!
