Anybody have a better system for removing 32 year old caulk from needle cut brick?
I’ve tried paint stripers, acid, heat torch looking for something better.
This compact detatched accessory dwelling has an efficient layout with a vaulted ceiling that enhances the sense of space.
What about a solvent like "Goo Gone" or "Lift Off?" The label usually lists a long string of things it can dissolve, often including dried latex paint -- so maybe it would soften caulking? I've seen it in lots of stores & HI centers...
how about pecking away with an ice pick
no turn left unstoned
Take a look at http://www.prosoco.com. They manufacture cleaning/ restoration/ protection chemicals specific to almost any kind of masonry staining or soiling situation imaginable, and I believe they make a product specifically for removing caulk from brick. Though you may find their prices a bit steep, I have seen restoration contractors use them to make walls and sills that I would have sworn were impossible to clean appear almost brand new. I believe they are distributed through CPD- the concrete topping and patching people. Hope this helps.
