Removing Paint from Basement Walls
chillywilly | Posted in General Discussion on March 25, 2004 08:52am
I am getting my basement ready to be finished and want to apply UGL Drylok the walls.  The walls are currently painted.  What is the best, fastes way for me to remove the paint.  Approx. 500 SF of wall space to remove paint from.  I don’t think sandblasting is an option since I don’t own one, or know how to use one!
Any chemical or sander suggestions?
  1. csnow | Mar 26, 2004 03:24pm | #1
    Do you have a finished floor?
    If not, you can use a pressure washer.
    Get a powerful one (3500PSI or more).
    Uses less water than one might expect.  You can keep up with a shop vac, or make a 'well', and use a utility pump.
    BTW, it might be easier to put a membrane on the wall, and provide drainage channels below.  More affective too.
    Edited 3/26/2004 10:34 am ET by csnow
    1. crosscutter1 | Mar 28, 2004 04:47am | #3
      go to drylock web site and ask them there might be a bonding agent or a primer you could use prior to using the drylock. if not sand blasting sounds like the best option rent one its not that tough to use
      1. darrel | Mar 28, 2004 05:42am | #4
        My understanding is that drylock, to work as advertised, has to be applied only to clean, porous concrete. If it just sits 'on top' it's really no different than any ol' paint.
  2. darrel | Mar 26, 2004 03:29pm | #2
    Are you sure you don't already have a dry-lock type paint on the wall? If you do, there is no point painting it again, since the dry-lock stuff is a one-time only deal.
    We had our walls painted with it, but they failed due to the previous owner not grading the ground around the house properly. So we fixed the water problem and will just be covering the ugly walls with new floating walls.
    rjw | Mar 28, 2004 05:54am | #5
    Treat the problem, not the symptom - that sort of paint is a tempoary fix only.
    _______________________
    Tool Donations Sought
    I'm matching tool donors to a church mission to Haiti - we're shipping a bus converted to a medical facility in (now it looks like) April and can fill it with clothes, tools and all sorts of stuff needed in that poorest of all countries. A few hand tools or power tools can provide a livelihood for an otherwise destitute family. Please email me if you have tools to donate.
    Thanks to Jeff and David and Jim and Rich and Steven and Mark and Jason and Shep and Jen and Mike and Joe and Bill and Ken for their offers!
    Several donations have arrived! Thanks and God bless!
