Removing Paint from Masonry
| Posted in General Discussion on October 3, 2000 07:30am
As part of my kitchen renovation I would like to remove the paint from a beautiful masonry fireplace. I tried Bix (sp?) to no avail and I don’t want to screw it up. How do I remove paint from masonry?
  1. Guest_ | Sep 25, 2000 12:40am | #1
    Dear J. Fish,
    Really? Bix had no effect? Are you laying it on heavy enough? Or are you using the spray bottle they sometimes give you w/ it?
    Ditch the spray bottle, lay it on heavy w/ a 4" throw-away brush - be sure and just lay it on in one direction - do NOT work it back and forth.
    Let it do its thing - then scrape it off w/ a plastic spatula or other plastic, flexible putty knife. You can buy those flexy plastic Bondo spreaders real cheap where ever they sell Bondo - those things work wonders for a whole lot of applications.
    Is it brick or stone? Because after paint-remover does all it can do w/o driving yourself nuts, I'd think a light sand-blast (if you got good mortar joints) would do the trick as a final step in finishing the job. And you can always re-point the thing if some of the mortar comes loose from the chemical or mechanical processes of paint removal. At least in theory (S).
    yours,
    Geo. Lentulo
    1. Guest_ | Sep 25, 2000 12:39pm | #2
      *check with a good masonry supply for graffiti remover. Yours is a much bigger job, but it might work for you. Best of luck.
      1. Guest_ | Sep 26, 2000 01:56am | #3
        *Just in case....When George says "Let it do its thing" he meansb waitfor the amount of time the instructions on the can say to wait. Don't get impatient.Rich Beckman
        1. Guest_ | Oct 03, 2000 07:30am | #5
          *Sandblasting always seems to work for me.
  2. J._Fish | Oct 03, 2000 07:30am | #4
    As part of my kitchen renovation I would like to remove the paint from a beautiful masonry fireplace. I tried Bix (sp?) to no avail and I don't want to screw it up. How do I remove paint from masonry?
