Removing paint from stain-grade trim
Biff_Loman | Posted in General Discussion on April 11, 2008 07:33am
Because of forces outside my control, I ended up installing all the cherry trim on my current project prior to painting.  All the trim has three coats of polyurethane.  150′ of baseboard alone. . .  ’twas a lot of masking.
Although I tried to be fastidious with my masking, I know that there are some points where paint crept under the tape.  I feel I did OK on the whole, but I’m going to have to fix some of these boo-boos.
Scrape it?  Sanding sponge, then touch-up with poly?  Any other ideas?
    Sphere | Apr 11, 2008 07:39pm | #1
    Goof-Off is a miracle in a bottle. Won't adversly affect the cured poly, but will lift dried latex paint from it.
    "Welcome to Poo-ville, can I have your socks?
    Seriously Folks, I need a home for 3 lovers of your life.
  2. peteshlagor | Apr 11, 2008 08:03pm | #2
    What Sphere says.
    Next time use frosted transparent tape on the trim, then blue stuff over it.
  3. PhillGiles | Apr 11, 2008 08:31pm | #3
    1) As said: "Goof-Off".
    2) Primer can be tough, but often latex that hasn't been on long can be removed from a shiny surface with a plastic pot-scrubber before you use the Goof-Off to clean the details. We use Goof-Off on Q-tips, orange sticks, and dental picks on fine details - it's not as labourious as it sounds.
    Phill Giles
    The Unionville Woodwright
  4. Biff_Loman | Apr 11, 2008 11:10pm | #4
    Great - awesome, thanks!
    I don't think I have too much in the way of primer on the wood, but I have yet to unmask everything.  I'm just about the roll the last of the first coat.
    It just occurred to me that this master bedroom suite is about the same size and complexity as the main floor of my house.  It's not a McMansion or anything.  My house is just really small.  Still, this thing is a chunk of work.
    1. peteshlagor | Apr 11, 2008 11:27pm | #5
      Take your time.  There are no awards given for getting done ahead of schedule in your own house.
      There's just the DW telling you that it looks like h*ll otherwise.
      1. Biff_Loman | Apr 12, 2008 12:46am | #7
        It's not my house - just the size of my house! :-D
    BarryE | Apr 11, 2008 11:45pm | #6
    Save yourself some money, goof off is 95% xylol and xylol is much cheaper
    Use the xylol (xylene), a flex putty knife and a rag to cut a straight line on your moulding or just the rag to clean drips. won't harm the finish
    Painters have used it for years
    Barry E-Remodeler
    1. Jim_Allen | Apr 12, 2008 12:56am | #8
      Geezuz! The things I don't learn here at BTU!!! Bob's next test date: 12/10/07
        BarryE | Apr 12, 2008 01:32am | #9
        So, what didn't you learn today? <g>
        Barry E-Remodeler
        1. Jim_Allen | Apr 12, 2008 02:47am | #10
          A lot...but I'm glad I learned about xlol! I've got paint cleanup duty next tuesday. Bob's next test date: 12/10/07
