removing plaster from ceiling
C1802362 | Posted in Construction Techniques on January 21, 2012 09:15am
This is a bit of reverse Breaktime topic, but any and (most) comments will be appreciated.
I’m remodeling a bedroom in my house to be used as a library. The room’s ceiling (dating to about the 1830’s) is plaster. Sometime in the last 50 years, the ceiling was overcoated with a textured layer of plaster, which I’m trying to remove.
I’ve tried a number of methods to remove the textured layer. What I’m learning is that if the textured plaster is thick (.030-.070 inch), a sharpened scraper easily pops off the textured plaster and leaves the original ceiling smooth and ready for paint.
If the plaster is thin, (<.030 inch), the only way to get the plaster off is to chisel it using the scraper and a hammer at a very steep angle, which is slow and chipping into the base plaster.
I’ve also tried my Fein oscillating tool, an orbital sander with 60 grit, and pre-wetting the plaster before scrapping with less than desireable results.
Any suggestions? I’m getting a nice palm bruise from the scrapper butting into my hand.
Art
  1. DanH | Jan 21, 2012 09:26pm | #1
    Did you try the scraper blade in the Fein?
    I wonder if there are any moderately priced hammer drills that can be converted to power scrapers?
    1. C1802362 | Jan 21, 2012 09:45pm | #2
      scraper blade in the Fein tool
      I tried both a new blade and one with the teeth gone on the lowest speed setting and it was far too aggressive.
      1. DanH | Jan 21, 2012 10:57pm | #3
        I'm talking about the scraper -- smooth, sharp blade with no teeth.
        1. C1802362 | Jan 22, 2012 12:17pm | #5
          the scraper
          Hmmm...
          I'll give your suggestion some thought
    oghrenovationsinc | Jan 22, 2012 10:00am | #4
    scraper blade
    they make a craper blade for use in sawzalls.  availabe at HD
  3. junkhound | Jan 22, 2012 01:43pm | #6
    Weld a scraper blade onto an air impact chisel - one of the $7.95 air hammer kits from HF works great for this low power stuff.
