removing shellac from wood floors
| Posted in General Discussion on May 25, 2004 10:03am
I’m attempting to remove shellac from old oak floors in a 1020’s Chicago bungalo. The usual sanding doesn’t work. No matter how coarse the grit, the sanding drum gums up immediately. The floor is left with patches of gummed shellac. How do I remove it?
David
  1. jackplane | May 25, 2004 10:11pm | #1
    Denatured alcohol and a scraper. Also you could use chemical strippers, but this is the least toxic method.
    Sphere | May 25, 2004 10:44pm | #2
    what he said. maybe try a heat gun too..it'll get real sticky, then brittle and dusty..find the right amount of heat and yer in business..then alcohol, for you and the floor
  3. OneofmanyBobs | May 25, 2004 10:50pm | #3
    Lye works.  Ammonia, the non-sudsy type, also works.  Less expensive than alcohol.  Alcohol is highly flammable used on a floor.  Ammonia requires a full-face respirator.  Lye does not, just gloves.  Lye needs to be rinsed several times with clean water and neutralized with baking soda.  Ammonia just needs a rinse.  I have not tried citrus strippers, but they may be reasonably safe.  You still need to sand afterwards.  Any alkaline chemical will darken oak.
  4. ed2 | May 26, 2004 01:20am | #4
    go to a ballistic grit....   16 or even down to 12     pebbles on paper, but if you have a lot of square footage the chemical strip and scrape will take a lotta time
      Sphere | May 26, 2004 01:22am | #5
      and you are crazy for recommending THAT..ever try it? If not you are in for a suprise Gomer. The poor guy will run outta thickness tryin to sand out the GOUGES..
      1. DougU | May 26, 2004 02:16am | #6
        What do you really think of 12 grit paper?
          Sphere | May 26, 2004 02:25am | #8
          'bout the same as what I call zero grit..take rock and rub vigorously..it's about the same. Make sure it's a hunk of quartz with a lot of crystals stickin out, like a mid-evil mace.
      2. ed2 | May 26, 2004 02:59pm | #10
        yeah gomer, sand w it all the time...  do a lot of old multi families w ancient shellacs and varnishes, come out nice    and that's the application they make it for     the heavy paper loads up w old finish but doesn't completely fill up like a 24 or 36 so it maintains some cutting ability    keep the machine MOVING which a REFINISHER already knows, in the end you're cutting w a 36     the finish is removed but the surface depth of cut is limited     i end w the shellac taken up, relatively light scratching and my surface cut, that's how bad the shellac picks up on the belt
        now switch to a 36 to surface out and so on    floor is resurfaced without excess cutting    sanding is not for inexperienced machine operators, especially problem floors     a ho can install a nice floor if a decent carpenter/mechanic, but refinish work requires learned skill w the machine being operated     if any amount of square footage is being done, and the multi families i do can run up to 7k sq ft, you're gonna retire doing that one w denatured alcohol, etc....   but that's the difference knowing what you're doing, sport
          Sphere | May 26, 2004 03:11pm | #11
          agreed , but this is a HO...not you, and not me. Granted I may have refinished a total of 7 or eight jobs..none at 7000 SQ.ft , I still know what a HO could wind up with, even with 36 grt. it could be a catastrophy..
          what happens when the newly installed belt accidently overlaps his already sanded area too much? Please, ya can't expect a guy to learn all the tricks the first time out...you know where I'm coming from.
          1. chicagorehab | May 26, 2004 03:45pm | #12
            Thanks for your advise, as well as everyone else's advise. No need to worry about my lack of experience. I've built two entire homes, one duplex, and remodelled several multiple dwellings in my spare time over the years. I've resanded many floors in the past, just never ran across shellac before.
            David
          2. OneofmanyBobs | May 27, 2004 02:11am | #17
            The machine makes a difference.  Shellac melts very easy.  That's why it clogs the paper so fast.  A belt sander has more surface area on the belt than a drum sander.  Stays a little cooler and is a little better at not picking up crud.  There is also supposed to be some sort of anti-stick spray for belts, but I've never managed to find any to try.
          3. ed2 | May 27, 2004 12:30am | #15
            yup, that's why rental sanding equipment should go for a minimum of $10K a day by law      can't tell you the number of times i've had guys tell me "i sanded it myself" and there's 1/4" deep gouges across the floor      any deeper and someone would've handed him up some chinese food, the real stuff, from the hole in the floor    the best part is the wives... while these guys are showing off their landscaping jobs the old lady is usually talking to herself or pulling a cork out of a bottle of jack daniels
            speaking of which, my girlfriend wants to know what we're both doing on the tube at 0800hrs     don't you have a job to go to?   never liked her much
            Sphere | May 27, 2004 01:28am | #16
            A job?..to go to?  sure, I gots a bunch..today was my crib, next is the roof.., after that..more stones..(my house) I do not "go to a day job"...I am self unemployed..would not have it any otherway.
            BTW..no offense at the Gomer part...it just naturally followed SUPRISE..he said he had PATCHES of shellac, not a total redo after failing at 36..so MY thinning babalouie was 12 grt would be a disaster..wrong?
            be cool I'll be a fool..
              edit: my wife is a model for VS..Victoria's Secret
            Edited 5/26/2004 7:28 pm ET by SPHERE
          5. DougU | May 27, 2004 03:52am | #19
            Got any pictures!
            Sphere | May 27, 2004 04:16am | #21
            lookin yer bathroom..you'll see her.
          7. ed2 | May 27, 2004 04:10am | #20
            it was the way she said it    like we were both welfare rats just hangin around     it made me feel bad    it made me feel dirty    later i went out and got a bottle of Night Train Express, about 180 proof fine wine    they filter it through shopping carts    then i went to my jobs.............     really a model for vs?
          8. User avater
            Sphere | May 27, 2004 04:18am | #22
            why do ya think I hang around, ?  For the COOKIN?  Hell man, I do the cookin here..an husband duties..actually today is our 2nd wedding anniversary..gotta go, bye
          9. ed2 | May 27, 2004 04:45am | #23
            i do the cookin too   that's because she beats me   if you see a lot of eyes looking in the windows, don't worry it's not wild animals   it's us  we'll be on ladders like belushi in animal house   why didn't you tell us sooner???
  5. WayneL5 | May 26, 2004 02:24am | #7
    When hand sanding polyurethane I tried the anti-gum paper and it worked much better than regular garnet paper.  I don't know if it will work as well on shellac, nor whether it's available in belt form.
  6. pino | May 26, 2004 02:40am | #9
    Steel wool and alcohol. I did my parents entire house that way and the floors came out great.
  7. User avater
    rjw | May 26, 2004 05:12pm | #13
    >> I'm attempting to remove shellac from old oak floors in a 1020's Chicago bungalo.
    Why? Is this a flip or income property?
    Or are you going the "preservation" route?
  8. csnow | May 26, 2004 11:06pm | #14
    Consider:
    http://www.franmar.com
  9. fdampier5 | May 27, 2004 03:35am | #18
    Open all the windows, shut off all the pilot lights and use alcohol..
      Quick and dirty method is to get a string mop  (foam won't work, it melts) dump a gallon in a bucket and swab the deck like a sailor..  get everything damp and keep it damp for a couple of hours.. then take a scraper and scoop up the residue.  give the floor another mopping and scoop up the rest of the residue..  now rent a floor sander and you won't need those 24 grit or 36 grit paper.   Light buzz and it'll be ready for your refinishing.. (wish I had an easy way to do that!)
