Removing silicone caulk from glass
WalterD | Posted in General Discussion on August 22, 2007 03:18am
Hello –
A roofer applying silicone caulk to my skylights smeared a bunch of it across the glass itself.  He also left a hugh ugly bead along the perimeter seal.
Does any one have a reliable way to remove this stuff without dissolving the seals of harming the low e coating on the glass?
I’m antsy about just scraping it off and penetrating the low e coating.  Also worry about agressive solvents destroing the original seal or even compromising the thermo pane seal.
Ideas and suggestions are most welcome
Walter D.
  1. DanH | Aug 22, 2007 04:11am | #1
    Is this on the inside or the outside. Shouldn't be any sort of coating on the outside. I'd probably cut/scrape, maybe use one of the caulk removers sparingly -- keeping it off of the seal proper. (However, the seal should be urethane and impervious to most caulk removers.)
    1. WalterD | Aug 22, 2007 05:16am | #2
      Caulk is on the outside.  Never occurred tome the coating would be on the inside; but, it makes sense now that i think about it.
      If coating is on inside and caulk on outside, seems i have a clear path to whale away with a scraper or caulk remover - any recommendations on a remover?
      Walter D
        BillHartmann | Aug 22, 2007 05:37am | #3
        Lowes has a LiftOff brand of Silicon Caulk and Foam selant remover. It is in the by the solvents, paint removers, and Goof Off.I like it. But it does not really "remove" silicon, but does a better job than other things that I have tried. It softens it can sure the surface into a slime that you can wipe off.Without seeing it I would guess that it would be best to remove it all and then redo..
    popawheelie | Aug 22, 2007 07:01am | #4
    I would buy a box of single edge razor blades. Make sure they are sharp and nick free when you use them against the glass. They shouldn't scratch it if they are sharp and nick free. Maybe get a holder also. Tha's how i've always detailed glass that has caulking on it.
    1. DanH | Aug 22, 2007 01:51pm | #5
      Of course with a skylight there's a possibility that the outer layer at least is plastic.
Mortar for Old Masonry
