Removing slate laid on subfloor
georgep | Posted in General Discussion on October 25, 2014 01:30am
Hi,
I am taking slate up off a wood subfloor. The slate was put down with mastic not mortar. The problem I am having is that when I start to pull up a piece of slate, the slate breaks leaving a thin layer of slate on the floor which is very hard to get up.  If I heat the slate will that soften the mastic and help get the slate tile up in one piece?
Any other ideas for getting this slate up?
thanks, George
  1. DanH | Oct 25, 2014 03:15pm | #1
    You can heat it or use paint remover, but whatever you do, don't add 100 blank lines at the end.
