Removing stucco from glass
| Posted in General Discussion on January 30, 1999 10:55am
My stucco subcontractor did not mask or tape off the windows. He simply wiped the splatter off with a wet rag. Now there is a film of stucco on the glass that is difficult to remove. What is the best cleaner to use to get it off without damaging the glass?
Thanks,
Dave Henderson
  1. Guest_ | Jan 30, 1999 03:25am | #1
    Dave,
    I know that this shutting the gate after the horse has bolted but in future get the contractor to mask up the joinery and spray a little diesel or WD40 on the glass first. You could try back charging your contractor?
    Regards
    Mark
    1. Guest_ | Jan 30, 1999 10:55am | #3
      *Dave:In the auto painting industry we take a single edge razor blade to anything that gets on glass. Use a little glass cleaner as a lubricant if you like. Check the blade edge often to make sure it doesn't develop a nick that will scratch the glass.Frank
  2. Dave_Henderson | Jan 30, 1999 10:55am | #2
    Thanks,
    Dave Henderson
Versatile Vise
