Does anyone have a good method for removing an old thinset tile base from plywood subflooring? The object is to replace the existing tile floor with new 12″X12″ tile.
Upgrading the footings and columns that support a girder beam is an opportunity to level out the floor above.
How to Install Cable Rail Around Wood-Post CornersRelated Stories
Podcast Episode 665: Rough Concrete, Good Workwear, and Framing a High-Performance House
Podcast Episode 664: The Best of the Fine Homebuilding Podcast, Volume 8
FHB Podcast Segment: The Best of the Fine Homebuilding Podcast, Volume 8
Podcast Episode 663: Green Stains, Larsen Trusses, and Insulating Behind Stucco
Bob,
Grunt work. We don't like it, so we've gravitated toward a diamond cup on an angle grinder - in fact we now have 3 different sizes, 4-1/2", 5" & 7". It hurt to have to buy the 5" one, but a diamond epoxy cup for paint/epoxy removal only comes in this size, and in even the short run, it was worth it. We particularly like the diamond blades and cups made by Star Diamond in Canada. In our experience we've gotten better value per dollar spent with their products than with others on the market. How do we know? Whenever we use a diamond blade/cup we time a 5 minute segment and see how much progress the employee has made with a particular product on a particular job. We then chart the life of the blade/cup. It is very revealing!!! You can contact Star Diamond at (800) 282-6470. Even though they are in Canada and we're down here in Texas, we've experienced no difficulty in purchasing/shipping/receiving products from them.
Good luck,
Cliff.
*Bob,Messy grunt work.We've had real good results with those abrasive flap-wheels made specifically for concrete or masonry on an angle gringer.There are many brands available. I've only used the Makita brand because that's what's available at the hardware store. They work pretty fast and it's easy to control the amount of material you remove.You may already know this, but respiratory protection is essential. No insult intended -- I'm one of those that learned the hard way a few years back and hope nobody else ever has to.Dave
*Try a air chisel with a wide blade. It what works for me.
