Removing tons of nails from studs?
kbg523 | Posted in General Discussion on July 8, 2022 06:34pm
Hi-I am doing demo/deconstruction in my new 1950s house.
Took down A TON of paneling and old drywall from the walls, and I want to remove the hundreds (thousands?) of nails from the studs to have a clean surface.
Would it be better to get an oscillating saw and cut them, or pull them all with a hammer or nail pliers?  Or another method?
Never done a project this big so I want to ask some pros for advice!
Thank you!
    2sheps | Jul 08, 2022 07:46pm | #1
    I would pull them. Probably a straight claw hammer for drywall nails. Anything else I'd use "The Extractor" pliers. This is a great tool, pulls anything from brads to sinkers if you can get a grip on them. It needs about 1/8" or so at a minimum.
    1. kbg523 | Jul 09, 2022 08:10am | #3
      Thanks. Looks like those are discontinued but I will find something similar.
        ct_yankee | Jul 10, 2022 04:59pm | #6
        Try this:
        https://www.amazon.com/Bates-Puller-Pliers-Remover-Carpenter/dp/B07W1H1ZZL/ref=sr_1_5?crid=3MHF0S5WOUDVL&keywords=nail+puller+pliers&qid=1657486666&s=hi&sprefix=Nail+Puller+Pliers%2Ctools%2C56&sr=1-5
        I have a similar one by Cresent. Works great if you can get a grip on the nail.
    tfarwell | Jul 08, 2022 08:49pm | #2
    I'd use a 4.5" grinder with a cutoff wheel. It burns through nails.
    mikeljon | Jul 09, 2022 09:01am | #4
    Highly recommend a pneumatic de-nailer. About $50. Shoots nail back out. Also works for removing plywood sheathing (can send the nail through the panel and it pulls right up).
    1. kbg523 | Jul 13, 2022 01:52pm | #12
      I wish I had this earlier, before taking down all of that paneling!
    unclemike42 | Jul 09, 2022 10:30pm | #5
    I redid my basement and used a wonder bar to pull the nails. Vice grips came in handy for nails that had lost their heads. (then the wonder bar for leverage)
    I also had good luck with a pair of channel lock pliers. Tapping a few deeper instead of pulling is not the end of the world.
    But before you get too carried away, you might want to carefully look at how straight the framing is. you might decide to install strapping at right angles to the framing and shim to get a solid and straight surface for drywall, and most of the nails could stay where they are.
    1. kbg523 | Jul 13, 2022 01:52pm | #13
      Thanks!
  5. dustindawind | Jul 11, 2022 02:29pm | #7
    As an amateur, my question is: why pull them rather than cut and pound (as necessary)?
    Seems like you'd be leaving lots of voids where you don't need them. The holes are likely not so plentiful that it will cause a problem, but why introduce a potential problem and space for critters to crawl into when you can save time by cutting the nails off instead?
    1. kbg523 | Jul 13, 2022 01:58pm | #14
      I was more concerned with what would be more efficient use of my time and energy, and if I did lop off fasteners, would that be an issue in the future? Would the nail remnants be a problem when I was hanging new drywall, if I happened to drive a nail or screw into the same spot…
      I was basically curious what a construction worker/GC would do if they were renovating a house, when time is money.
  6. Tim_William | Jul 13, 2022 12:32pm | #8
    Ditto on a prybar, the drywall nails in my 1950s house come out easy and have large heads. A catspaw helps with any stuck ones. You can motor through the job quickly if your house is anything like mine.
    1. kbg523 | Jul 13, 2022 01:51pm | #11
      Thanks!
  7. florida | Jul 13, 2022 01:37pm | #9
    "Tons" of nails sounds like drywall nails to me. I can't see how you could have framing nails in your studs. Assuming drywall nails you give your 7 year old a claw hammer and tell him to go at it. Even a 7 year old should be able to pull all the nails in an hour.
    1. kbg523 | Jul 13, 2022 01:51pm | #10
      No kids. Maybe if I found a little league team and gave them some amphetamines and hammers they could all knock it out in an hour.
        unclemike42 | Jul 13, 2022 05:01pm | #15
        The paneling nails should pull with a pair of pliers for the most part. (good light and a pair of reading glasses if you use them is a good plan)
  8. mikemahan3 | Jul 13, 2022 11:54pm | #16
    One of the very best tools for pulling (not just cutting) nails is end cutting pliers. I've got a very large pair that will pull 16d s without much trouble. You need to squeeze hard enough for them to bite but not cut.
  9. ALexander738 | Jul 14, 2022 02:24am | #17
