Removing vinyl siding/ j channel
danz857 | Posted in Construction Techniques on April 13, 2008 04:06am
I need to remove an existing cheap spec house dryer vent hood that is totally gone in less than 7 years  THe existing vent hood is a one piece and I bought what appears to be a more durable 2 peice one. I may be able to install the flange by just removing what appears to be j channel framing the existing dryer hood but having a hard time with this, is there a trick to removing j-channel? Also if I have to remove the surrounding siding is there a tool or trick to removing it? The vent is located about 3 courses from the bottom of the siding. Thought this was gonna be an easy fix but then again if it was easy I would not be here asking questions.
Dan
    Sphere | Apr 13, 2008 04:10pm | #1
    Malco makes a siding "unzipper" available at Lowes..and the J channel is nailed (hopefully) and a small "weenie bar" or mini-wonderbar is helpful there. Careful, if it's cold, it's brittle and can crack.
    "Welcome to Poo-ville, can I have your socks?
    Seriously Folks, I need a home for 3 lovers of your life.
  2. LIVEONSAWDUST | Apr 13, 2008 04:26pm | #2
    Start at the course above the vent. try to grab a corner of a pc. with either a zip tool made for this purpose or a mini pry bar. sometimes I can just grab it with my finger, then pull down, you then should be able to unzip that pc. from the one below. I try to do this above 50 degrees or wait untill the sun hits it. Its brittle when cold
    1. danz857 | Apr 13, 2008 05:14pm | #3
      good tips, kinda cool here today, good excuse for not doing it today.
      Dan
  3. MSA1 | Apr 13, 2008 05:27pm | #4
    To remove the Jchannel, pull.
    The unzipper tool will really help you in putting it all back together. Its cheap and a worthy addition to any tool box.
    1. danz857 | Apr 13, 2008 06:13pm | #5
      Thanks, however if everything goes right i shouldnt have to put the j channel back on, the new hood should fit over the siding...... guess that is another question, does anyone know if I will need to do any caulking?
      1. frammer52 | Apr 14, 2008 01:17am | #6
        something
