Removing Yellow Flooring Adhesive
h8 2paint | Posted in Construction Techniques on May 6, 2010 11:01am
Hey Guys,
 I need some suggestions.  I have a 1250 sq ft room I am stripping off the floor.   I have already removed a layer of peel and stick floor tile with a tile ripping machine.  Beat me senseless for 8 hours yesterday. but the flooring is history.  Now I have the unholy task of getting the remains of the adhesive off the floor. Whoever placed the tile used peel and stick, as well as the “VCT” yellow adhesive.  I found some “Kleen Strip Adhesive Remover” in a gallon can, but this stuff is $ 25 a gallon, and getting 88 sq ft per gallon. nearly $400 for this stuff will break me.  Does anyone have any sugestions on a cheaper way to do this?  I mean this will work, but man… any help will truly be appreciated.
Thanks,
Tom
  1. calvin | May 07, 2010 06:54am | #1
    Have you tried H2O?
    Assuming you are trying to remove the adhesive from a wood floor?  You can't flood the area, but give this a try-it's free.
    Wet rag laid over the floor might soften the adhesive.  Might be able to srape off the softened adhesive.
    This the result of homowners dumping a bucket of water on the floor after recently pulling lino from the concrete.  Took them a while to find something to "sweep" the water towards a floor drain.  They used my push broom.  Remarkable that the adhesive softened and came up.  Also remarkable I ended up with a broom with one thick bristle.
Grout-Free Shower Panels
