repair a crack in vinyl window
bigbossman | Posted in General Discussion on July 28, 2007 06:55am
I want to know what I can use to repair a crack in a vinyl white window that will not be easy to detect when looked at but will hold the vinyl secure. No the part of  the window is never opening after the repair. Should I use a white caulk? What type? Or is there another item you can refer to me?
    Sphere | Jul 28, 2007 07:07pm | #1
    Melt it with a soldering iron and then pare it smooth with a razor blade. Sometimes a "borrowed" bit can be swiped from a flange edge to add filler to the repair.
    1. dovetail97128 | Jul 29, 2007 08:58am | #3
      HIJACK Alert Sphere, Did you receive the caulking tools , should have been there last Monday. If not I will trace them . Ok , back to the subject of this thread.
      Thanks.
      "Poor is not the person who has too little, but the person who craves more."...Seneca
        Sphere | Jul 29, 2007 02:04pm | #4
        10-4!
        Been swamped. Meant to email ya, but my email program suxx so bad I been shying away from it.  You should have a check right soon.
  2. k1c | Jul 29, 2007 05:42am | #2
    If the repair is just a matter of stabilizing the crack, the glues might help.  PVC glue for pvc and maybe superglue (gel type) for vinyl.  If the window is vinyl coated wood, such as Anderson, they will sell you a patching kit, which I have used successfully.  Hope this helps.
  3. ryder | Jul 30, 2007 01:14am | #5
    Here in the Seattle area I've had the opportunity to pay for a few cracks or outright holes chipped out from my framing crews and the sup just has a guy come out who fixes just that, maybe from the manufacturer, but if memory serves it's the same guy I've had to pay to fix scratched/chipped porcelein [sp?] tubs.  Would think your window rep would have a contact.  Was pretty cheap I think, but yersterdays a fog, so last years almost non-existent....
  4. Piffin | Jul 30, 2007 01:59pm | #6
    It can be welded back together with a soldering gun. That sometimes leaves a burnt color scar that you would need to caulk over. There are PVC welding rods that can be melted in with the right tip on a heat gun too.
A Practical Perfect Wall
  • The New Old Colonial
