I need some help from the painters in the group. I need to repair some dented and cracked bullnose on a mantle. What is the best putty, filler, paste or whatever to use. It will be painted again so not stain grade. It does need to be shaped to match the run and I’m not sure how to contour after the patch. Help please.
It's always a gues when you can't see it, but automotive body-filler may be your first choice over wood-filler. Use rifflers (small rasps) for primary shaping, then sand-paper.
Phill Giles
The Unionville Woodwright
Unionville, Ontario
I'd go with what Phill says, bondo. Dont mix it to hot and start forming it before it sets, a lot easier.
Ah, while we're here, there are a thousand little tricks; but, one key item may be the need to stabilize the moulding before you fill it (i.e. so it won't crack further - only you can judge if the crack is a one-time, or continuing). There are commercial 2-part and 1-part products for this; or, you can water down Weldbond 3:1 and soak some in..
Phill Giles
Unionville, Ontario
You can do it.... with plaster of paris.
Use small screws or nails to provide a strong key to the patch(1/4 bellow the surface)
Copy the shape of the molding on a plastic tape knife. (Is very Ez after you cut and remove the molding)
You may have to do this in two steps.
Good luck.
YCF
here's a couple of things we use on the restoration front for big dents wood epox by abatron, then sand, for the stuff lets say the size of a quarter the ubiquitous bondo aka min-wax wood filler. than for things for th size of a nickel m&k exterior filler/spackle or plaster of paris. for things smaller than a dime and if the time and more important the $$$$ there for mantles, front doors and other high profile items there's this stuff called swedish putty it expensive but a pristine job. it's a marble dust mixture, thats the stuff it's no good for things larger than a nickle. but for those difficult small nearly impossible dings to fill sand finish. i'm a big fan.......good luck bear
Dents in wood can sometimes be steamed out with a hot iron. put a wet cloth over it and add heat. Re-apply for about ten minutes
I've had success with that method taking dents out of floors and furniture
