Repair Door Jam Dent
johndrew | Posted in General Discussion on December 9, 2015 07:27am
I was installing counter tops in the bathroom and damaged the finished door jam when going thru the door.. Some dents  are about 1/4 inch deep 45 degree widge type dent. The others are about 1/8 inch scrape 1″ wide.  How do you suggest repairing after sanding off the paint? Should I drill holes to hold the putty? How big a drill bit? What type of filler?
  1. renosteinke | Dec 09, 2015 09:22am | #1
    Hello, Bondo
    Yup- the old auto-body  epoxy is your solution.
    Lots of fresh air, of course, is a real plus as it cures.
    Trowel it on.shape it, let it cure, sand it, paint it.
  2. calvin | Dec 09, 2015 08:25pm | #2
    John
    Most likely I would use some original Durabond that I keep around.  I'd sand around the area and clean any dust out of the damaged recesses, apply the Durabond a fuzz high, let dry and sand out.  Repeat if necessary (deep).  Prime/paint.
Two Ways to Test Windows
  • The New Old Colonial
