Repair or replace rotted corner post?
I was hired to repair a post-and-beam colonial: replace trim, clapboards, and gutter. When I removed the trim on one corner, the structural post and ends of the sills (all 8×8) were rotted and dripping. The rest of the sills are solid, there’s no sag in the building. Only the bottom 2/3 of the post is bad, where the attic floor beams join (it’s a one-story ell) is dry and solid. Same up to the top plate and end rafter.
Can I replace the rotted section only, avoiding the joinery above? Can it be scarfed or lapped with joining plates? Even better for a solo carpenter, can I build-up a post in place? If so, how would that join to the remaining original post?
Weird side-note – this post is visible on the interior. The interior corner stayed dry, not even a stain on the drywall after years with a bad gutter sending water behind the trim!
I can add photos and dimensions if needed. Thanks
I would think that a careful lap joint with epoxy glue (use some adhesive filer for gap bridging capacity) would be as strong as the original. You would need to support the load while you prep the post for the lap joint. Pictures would help.
