Repairing exterior stone steps
GLAUCON | Posted in Construction Techniques on January 10, 2006 06:01am
I have to repair my front steps, which are stone.  I have replaced some of the stone with good quality Pennsylvania bluestone, and have set the new stone in mortar in preparation to pointing.
There is one original stone that was loose, so I removed it. The mortar underneath it is in very good condition.  I’d like to reset it, but would rather not chisel out the mortar underneath.  The stone is level and just about 1/8″ below the one next to it.  Is there an exterior thinset adhesive that I can use to set it?  I was advised to use retaining wall repair stuff (which comes in a tube like caulk), but it doesn’t seem to hold against the rough surface of the stone.  If there is a particular adhesive that will hold the stone well, I’d like to use it… if not I can chisel out the mortar and do it the hard way…
Thanks in advance,
Glaucon
If you don’t think too good, then don’t think too much…
  1. paul42 | Jan 10, 2006 07:22pm | #1
    This isn't my area of expertise, but I have used a glue designed for cement blocks to build a small retaining wall for a planter for my wife.  The glue came in the large caulking tube and worked very well.  It is a type of eurathane glue and those cement blocks don't move.
    Sphere | Jan 10, 2006 07:54pm | #2
    PL Premium is what ya want. It will stick better than the mortar.
    1. GLAUCON | Jan 10, 2006 10:01pm | #3
      <<"PL Premium is what ya want...">>
      Thanks.  What exactly is this stuff and where can I get it?Glaucon
      If you don't think too good, then don't think too much...
        Sphere | Jan 10, 2006 11:36pm | #4
        finally! whew! the site is messed up or my 'puter is, took me a half hour to reply.
        PL is a polyurethane caulk available at Lowes for sure,don't know about HD. Excellent adhesive.
        1. GLAUCON | Jan 11, 2006 06:42am | #5
          Thanks- I'll give it a shot,
           Glaucon
A Practical Perfect Wall
  • The New Old Colonial
