Has anyone used refractory cement or anything else to repair soapstone (4 on the hardness scale)? This stone gets hot, so I can’t use the normal stuff like glue or epoxy. Thanks for any advice you can give me. larry
![](https://images.finehomebuilding.com/app/uploads/2024/07/16151624/01232580-building-matters-expect-unexpected-thumb-16x9.jpg)
Don't buy in to the TV show nightmares—when you uncover something unforeseen on a remodeling project, take these steps to keep the process moving and fix the issue.
Larry I used a epoxy a few years ago on a grill that was rated at around 2000 deg. I belive Master Builders (concrete Chem. Company) had the stuff or directed me to it. This was around a few years ago and the grill is still holding up. Email me if you can't find it and I'll dig through the files and find this stuff for you.
*Larry,
Joseph FuscoView Image
*You might want to contact Vermont Soapstone Co. at 802-263-5404 (FAX 802-263-6451) for their opinion.
*"Hot Stuff" cyanoacrylate glue does a fine job on soapstone. You may even think about immersing thesoapstone in this stuff. The glue is found in any woodworker's catalog.
Has anyone used refractory cement or anything else to repair soapstone (4 on the hardness scale)? This stone gets hot, so I can't use the normal stuff like glue or epoxy. Thanks for any advice you can give me. larry
