replace oldstyle flapper
rez | Posted in General Discussion on May 24, 2006 12:21pm
In prep for mounting a new flapper, what’s the best way to remove the metal ring and flapper which was adhered down to the old ceramic tank on the stool all those decades ago so the replacement can be made?View Image View ImageView ImageView Image
Thanks  View ImageView Image View ImageView ImageView Image View Image View Image  View ImageView Image
View ImagehalfView Image View Image
Edited 11/19/2006 4:45 pm ET by rez
  1. kate | May 24, 2006 01:09am | #1
    Bump...
    1. rez | May 24, 2006 02:37am | #2
      View ImageView ImageView ImageView Image
      Edited 11/11/2006 10:11 pm ET by rez
      Edited 11/11/2006 10:27 pm ET by rez
      1. Shep | May 24, 2006 03:26am | #3
        If your talking about a toilet flapper, I'd be careful about using a heat gun on the toilet.
        You might end up cracking the porcelain if it gets too hot.
        Of course, if it was me doing it, I'd end up breaking the toilet anyway during the repair, and end up getting a new one.
  2. plumbbill | May 24, 2006 06:34am | #4
    Just the flapper or the whole douglas valve?
    I wouldn't worry too much about heat since the bowl  & tank are fired viterous china--------BUT if there is a fision in the china & ya got moisture then it will pop.
    Do you look to the government for an entitlement, or to GOD for empowerment. BDW
  3. cynwyd | May 24, 2006 06:46am | #5
    put something on the bottom of the tank to spread the load and pry it off
Shoulder Your Buckets
Add a strap for easy carrying and pouring when working with 5-gal. buckets.
  • Townhouse Transformation
