Replacement door jambs
gdcarpenter | Posted in General Discussion on July 4, 2004 04:06am
Looking for replacement exterior door jambs of a ‘man made’ material, client doesn’t ever want to have to replace same said jambs again.  Thought I saw something like that in FHB (or – oops – JLC), anyone recall or know of such?
Let’s not confuse the issue with facts!
  1. FastEddie1 | Jul 04, 2004 04:17am | #1
    Some of the new pre-hungs that I am ghetting have a piece of composite material (like trex) for the threshold and the bottom 2 inches of the jambs.  Contact your local door mfgr and see if that will sell you jamb material.
    Whenever you are asked if you can do a job, tell'em "Certainly, I can!"  Then get busy and find out how to do it.  T. Roosevelt
  2. butch | Jul 04, 2004 01:24pm | #2
    Home cheapo carries a ext. knock down all vinyl jamb. I believe it was close to the
    same price as a regular jamb. With the  vinyl brick mold your good to go.
  3. DanH | Jul 04, 2004 05:00pm | #3
    Does he know that whatever he puts in won't be "maintenance-free"? That if conventional door frame failed it means that there is a bad moisture condition that can get past the frame and into the framing, interior floor, etc?
    1. Snort | Jul 04, 2004 06:50pm | #4
      Lowe's Contractor Yard in Durham has Therma Tru doors with 6" of composit jamb & brickmold, along with composit under the sill. Don't worry, we can fix that later!
  4. SonnyLykos | Jul 04, 2004 09:36pm | #5
    If you do't want to use the PVC jambs sold by HD and many lumberyards, consider going with KDAT, also made my lumberwyards, otherwise you can make them yourself.
    I've gone with the PVC jambs. Those I buy are white but the inside is a brown color - a plastic (or composite) that is more dense to hold screws better.
      gdcarpenter | Jul 04, 2004 11:43pm | #6
      Thanx y'all.  It's just ground splashing that's rotting the lowest bits of the jamb.  Acutally looked at HD and lo and behold they had PVC'ish replacement jambs.Let's not confuse the issue with facts!
      1. SonnyLykos | Jul 05, 2004 12:01am | #7
        That's exactly what I use to replace rotted bottom jambs for condo associations and private homes. Just make sure the profile dimensions are the same, since I've found some to be different.
  • A Postwar Comeback
  • Natural Simplicity
  • A Grand Rescue on the Coast
