Replacement Insulation for Furnace
Searles Lewis | Posted in Energy, Heating & Insulation on April 13, 2015 05:56am
I have an airease a95. I turned in a child molestor/drug dealer, and was gangstalked by my maintenance man (convicted drug addict) and some next door neighbors, one of them being a sheriff’s deputy who advised him to spray imidacloprid with glycerine poison into my plenum, and it aerated up into the blower assembly.
I tried reporting to the police since all of this started 4 years ago, but was given a death threat, and I live in NM, and you can see from the evening news what type of police we have here. I spoke to a lawyer, he said the police will do nothing as they are part of the source of the problem.
So, after I used the npic to identify the poison, I needed to clean it up. The blower unit has two 2×4 insulation dark 1/4 inch insulation pads on either side of the blower. I cannot clean the poison off of it, so I want to replace it with the exact same insulation that was coated. However, no one has ever answered the airease phone no matter when I have called, and all of the local hvac supply dealers have refused to sell anything to me without showing a contractor’s license.
Does anyone know how I can get the same exact insulation to replace it? Where? Heom Depot does not stock it, and the only thing they have that resembles it is a radiant barrier with foil. Where can I get the exact same replacement parts?
  1. DanH | Apr 13, 2015 06:26pm | #1
    The "insulation" on the
    The "insulation" on the inside of a blower is there for vibration/noise suppression purposes, not anything to do with heat.  If you don't mind the noise (hard to predict how much there would be) you can just remove it.
    If you do replace it you should use something that is not readily flammable, and it should be something that has good vibration suppression characteristics.  I'm thinking pieces of "beaver board" house sheathing would work.
      MarkH | Apr 14, 2015 06:26am | #2
      What the Hillary is beaver board?
      1. DanH | Apr 14, 2015 07:33am | #3
        There's this thing known as "Google".  Yes, it is a liberal conspiracy, but try it some time -- you might find you like it.
          MarkH | Apr 14, 2015 12:26pm | #4
          Yuck, google took me to a perverted porn site. And I never thought a girl could do that to her beaver, holy cow.
    coonass | Apr 14, 2015 10:32pm | #5
    Searles,
    Paint it with some 1200 degree paint or cover it with some sheet metal. This is the same chemical you put on a dogs back to prevent fleas and ticks. I would call State Police and EPA.
    KK
