How much do you guys charge to install a kit style replacement window?
The FHB podcast crew chats about whether or not coil stock on fascia and rake trim is necessary.
Video: Build a Fireplace, Brick by BrickRelated Stories
Why do you ask?
I wonder if I am charging enough?
Kit as in sash & jamb replacement?
Yes. Not a replacement window unit. A kit including an inner/lower sash, an outer/upper sash, two jamb tracks/balances etc. A brosco product like the Jeld-Wenn(?) Sash Pack.
no less than $125.00. Consider your time involved in measuring, ordering, disposal etc.
Seems to me that the better question for something like this would be how much time does it take, considering all associated activities. Hourly rates vary at least 2:1 between different areas represented here.
