Replacing/adding lintel to support brick
TrimButcher | Posted in Construction Techniques on December 23, 2002 06:06am
1) I want to enlarge a basement window so that it’s an egress.  Basement walls are poured concrete with brick exterior.  Current window has a steel lintel, L-shaped profile, forms a “box” around window opening.  Anybody know if I can cut the bottom out of the steel box so that I can simply put in a taller window?
2) If I have to put in a new lintel, how do I temporarily support the brick as I remove the old lintel?
Thanks in advance,
Tim
  1. FastEddie1 | Dec 23, 2002 06:15pm | #1
    Take out the window.  Put a temp support beam (or two) through the window, supported on both sides.  Remove the brick, concrete, studs, etc from the bottom of the opening.  Weld on same-size lintel extensions.  Patch the opening as needed.  Remove temp supports.  Ergo, egress.
Rescuing Old Hardware
Whether it’s already in your house or picked up at a flea market, vintage hardware almost always needs help.
  • Townhouse Transformation
