replacing floor joists
mrhodes | Posted in Construction Techniques on September 13, 2003 06:09am
What is the best method of replacing floor joists?  About 3/4 of them need replaced.  It is a 2′ crawl space and really needs raised another block or two.
    teasea | Sep 16, 2003 02:38pm | #1
    I would remove the subflooring all of it! I dont like crawling around in dark places with spiders and snakes! sounds like a nasty job you have my condolence
    1. honeydoos | Sep 16, 2003 03:28pm | #2
      I agree, remove the subflooring and go from the top.  Don't like spiders and snkes at all.  Besides which if that many need replaing the subfloor probably does too!
  2. Piffin | Sep 16, 2003 04:03pm | #3
    As a general rule, I agree with these guys. But it might depend on the oerall situation and you give little background info about type of construction, reason theyneed replacement, whether rim/sill needs to go too, type of sill and foundation, condition of house, etc.
    1. mrhodes | Sep 17, 2003 05:24am | #5
      It is a basic ranch style house with 2X4 framing and only 2X8 joists.  I think I will go with the over the top method.  Thanks you all.  Yeah, and the problem was caused from excessive moisture in the crawlspace.  I think the downspouts put it right in there.  Do termites prefer moist or dry wood?
        teasea | Sep 18, 2003 07:03pm | #6
        sounds like someone stuck the clothes dryer exaust pipe into the crall space, crall space not vented ,install vapor barrior   and curtain drains for down spouts
  3. Frankie | Sep 16, 2003 04:15pm | #4
    1. Remove the sheathing.
    2. Replace only a few joists at a time.
    3. Resheath.
    Piffin maks good points. If the joists need replacement, so may be other parts of the framing.
    F
