Replacing mortise locks
habilis | Posted in Construction Techniques on January 3, 2009 10:29am
Hi, I need to replace some old skeleton key, mortise locks on exterior doors. Since fitting the mortise doesn’t look likely, I’m going to replace with new locking knob set. First thought is to remove old lock, cut and glue wood block into mortise and finish with a normal lock installation. Best plan? Cold weather a problem for glue?
Thanks.
  1. McMark | Jan 03, 2009 10:37pm | #1
    It would be pricy, but why not replace the old mortice set with a new one?  Probably (maybe?) be able to retain the holes.
    Dinosaur | Jan 03, 2009 10:46pm | #2
    I agree with trying to replace the old mortise lockset with a newer one, as the better way to approach this, but if that doesn't fit your plans, you can do as you suggest. Cold weather won't bother the glue joint if you use an exterior-rated carpenter's glue.
    Dinosaur
    foolish men call Justice....
  3. Piffin | Jan 03, 2009 11:21pm | #3
    yep, glue it in after fitting it snug. Gorilla glue would be good for this because it is less affected by cold and will fill minor gaps. Then use Bondo or minwax wood filler and sand it out smooth, repaiunt, and go.
  4. Shep | Jan 04, 2009 12:24am | #4
    I've done what you want, using quick-set epoxy to glue the blocks in.
    First, you don't have be as fussy getting the blocks to fit properly, because the epoxy is gap-filling,
    Second, because its quick setting, you're not waiting so long for the glue to dry before you can continue.
  5. reinvent | Jan 04, 2009 01:45am | #5
    here are some replacement options
    http://houseofantiquehardware.com/s.nl/sc.10/category.16/.f?GCID=S14464x015&KEYWORD=mortise%20locks&partner=gpc&gclid=CILIk9C685cCFQrAGgod2CXvDg
    http://www.deabath.com/Hardware/Mortise/mortise.htm
    http://www.rejuvenation.com/typepagelocks%20and%20parts/templates/houseparts_group.html
    1. habilis | Jan 04, 2009 01:58am | #6
      Unless I missed something, these all have skeleton keys. Agency that inspects rental properties won't accept skeleton key locks on exterior doors.
  6. brucet9 | Jan 04, 2009 03:53am | #7
    Ordinary rental property? glue in a block and bore for standard 2 1/8" keyed entry lockset.
    Historic property or good example of pre-WWII architecture? Get a good mortise lockset installed.
    http://doorhardwarecenter.com/dsp_cats.cfm?catID=5&manufacturerID=1
    http://www.atouchofbrass.com/c-156-mortise-locks.aspx
    BruceT
    1. habilis | Jan 04, 2009 05:56am | #8
      Ordinary, going w/original plan.
