Greetings,
I need to replace a bunch of Andersen Pressure Seal double hung windows.
<http://www.andersenwindows.com/homeowner/pdfs/Pressure_Seal.pdf>
I’m looking at vinyl replacement windows. For those of you that have done this, did you cut the exterior window stop, insert the replacement frame/buck and then attach a new ext stop? These windows don’t have a interior stop that can be removed. And how do you deal with the fact that the depth of the side jamb recess is deeper on one side than the other? Pad it out after removing the old sashes? Or just order the window with a width a little smaller than the opening so that you can center it?
cheers,
eric in CT
Greetings eric,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again.
Perhaps it will catch someone's attention that can help you with advice.
Cheers
when in doubt add garlic
bump
well eric, we'll run it thru one more time.
Well, Eric came back numeroous times but no sale.
be ashamed.be very ashamed.The end move in politics is always to pick up a gun. R. Buckminster Fuller
